drschwartz (Replacing Rear Shocks)
What is the prceedure for replacing the rear shocks on a 1993 lincoln town car executive ? I have the special tool for holding the upper end of the shock, however I can't find a way to get it in there.
Are your shocks within a spring?
If not, you just raise vehicle, remove center bolt, then remove lower bolt.
If it's within a spring:
Unbolt the 3 outer nuts on top, and LOOSEN the center shock nut
Remove lower bolt
Spring and shock come out as an assembly
Then you put on your spring clamp tool
Remove center nut completely
Remove spring clamps
Shock will slide out
Install in reverse order.
Remove lower bolt
