ran out of gas, idles low
I ran out of gas, in my driveway. I put 10 gallons in but when I turn the car on, it hesitates and idles so low it feels like it's going to shut off. now I'm afraid to pull out of my driveway. 2000 Ford Explorer, 8 cylinder.
my 2 cents
I would never ever let my car get so low on gas you are risking a quite expensive repair. My 2000 ford had a fuel pump failure and it cost me big bucks over 1000 dollars to have it replaced. (I had a full tank). Reason is the fuel keeps the pump cool in the tank and keeps air out of it. I dont know if I would drive it with a plugged filter as you might mess up injectors if some of the crud gets by. Yes this is my advice always keep at least a 1/4 tank because late model Ford fuel pumps are costly and not easy to replace.
