HELP! Can't find 1998 caravan 3.0 AC recharge fitting.
Old 06-18-07, 08:31 PM
G
I found the evap service port ( tire valve looky thing) , and the big valve, but can't find the recharge on this van follwing the lines that my recharge kit hose connects on to. Does anyone have a pic or location ?.. I'd appreciate it.. emailaddress@notallowed
Last edited by HotxxxxxxxOKC; 06-18-07 at 08:37 PM. Reason: Mod note: removed email address
Old 06-18-07, 08:37 PM
HotxxxxxxxOKC's Avatar
Some are tricky. I have no picture, but, it has to be on the low side tubing. Usually indicated by a blue cap or maybe black.
Some ports you have to get up underneither to see. The hose will only fit on the low side, so you cant make a mistake.
Follow the larger of the two lines coming from the compressor to the accumulator.
