2003 Hyundai Accent
Old 06-19-07, 02:44 PM
P
2003 Hyundai Accent
I'm having gas problems with my 2003 Hyundai Accent GL. The vent hose that lets air escape when I fill up the car with Gas keeps getting clogged up by these little charcoal pebbles. I keep emptying out the vent house but the pebbles keep coming back. Does anyone know what those pebbles are and why they keep clogging up the vent hose? Any help will be greatly appreciated. Thanks!
Old 06-19-07, 03:14 PM
W
At some point............somebody tried to squeeze the extra drop in the tank on fill up...........You got raw fuel into the canister.......and now the charcoal has found it's way into your tank..........
Run it to as close to empty as possible............remove the tank and clear the charcoal.........Blow out the lines to the cannister..........and replace the cannister
Old 06-19-07, 03:50 PM
HotxxxxxxxOKC's Avatar
Wrench hit it on the dot.
This canister is also called the EVAP canister.
Old 06-21-07, 01:11 PM
P
So I have to take of the gas tank clean it out of any charcoal.... but what is the canister that you’re referring to? Is it the box that the vent hose lead too?
Old 06-21-07, 01:13 PM
Yes, this canister filters out the fumes so it's not all released into the atmosphere.
Usually it is round.
