HELP!!! 96 Astro will not start - Fuel Suppl./Press. ctr.??
Received 0 Votes
I have a 96 Astro with 110k, 6CYL. The fuel pump will not come on. I replaced the pump and filter - still the same problem. I replaced the relay - no luck. I then jumped the conection on the relay port - and the pump will run. The relay is energized thru ECM. Once the pum is running the engine will start and run - once I remove the jumper to run the fuel pump the pump stops and engine stops running. Is there a pressure switch or something of that kind what tells the pump to turn on? Thank you for any help you can give me.
Sven.
Sven.
Received 0 Votes
Really! YOU TOO!!
Had the exact same problem.
Check the connection on the top of the fuel pump carrier. (where the wires go through the top of the tank) I think that yours should be a yellow connector. Unplug the wires on the inside of the tank and check out the pins. If any of them look black or burnt, or look like they have a tar like substance on them, there's your problem. Bad connection. Hopefully, the harness from the carrier to the pump is the problem.
Here's a link that solved my issue:
http://www.carterfueldelivery.com/fuelpumps/pdf/training/fts1.pdf
I messed with this 3 times. It never failed that right after I topped off the 26 gal. fuel tank, the darn thing would die...
