A/C dripping noise, brake clicking noise
Old 06-20-07, 11:01 AM
Unhappy A/C dripping noise, brake clicking noise
I just got a number of things done on my car including replacement of the rotors and pads, oil change, heat shield clamp, left tie rod, alignment, check of fluids and fixing battery cable that had come loose.
I am hearing two noises I never heard before as follows:
1. A drip every few seconds over toward the passenger side when I have the a/c on (a/c stopped working last October and was repaired); and
2. A click when I give that final push on the brakes when I come to a stop at a light. It is a quick sound like metal bending.
Any ideas what these noises are?
Thanks in advance.
Linda
Old 06-21-07, 10:43 AM
Sorry, forgot to mention that the car is a 99 Ford Escort Sport.
Old 06-21-07, 11:08 AM
HotxxxxxxxOKC's Avatar
This could be a clogged evaporator drain. Have the technician take a look at it. There is a small drain hose under the pass. dash area that should drain the condesation from the AC to the outside of the vehicle.
The bolts to the calipers may not be properly torqued. That would be my guess.
