95 Grand AM 4cyl
Received 0 Votes
This car was cheap, but used to run great. I noticed it missing when cold, but acceleration would get it running smooth. Now it runs ruff all the time. I replaced the plugs to no avail. I found a vacume leak that seemed to have been rigged before. The hose collapses (probably because it is just a heater hose) and causes variations in idle when disconected or pinched, but doesn't seem to smooth out the engine any.
A friend said it might be the coil-pac. Auto Zone said it might be an injector. I thought it was the plug wires, but allas, it doesn't have any. If someone could help me with this car, we can then get my 96 Chevy pick-up running better... what fun these polution free computerized vehicles are.
There are many possibilities, but lets start with the basics:
Have you replaced your fuel filter?
EGR valve maybe clogged or defective.
Have you checked your timing?
Received 0 Votes
Thanks Mark,
The way the engine is running is as if a cylinder is not firing. It kinda sounds like a lawnmower. It doesn't backfire or frontfire and it doesn't seem to want more fuel (hesitation or stalling). The check engine light is not on. Can you actually check the EGR valve somehow and where is it? What do you think about the coil-pac possibility?
Bart
Bart
Received 0 Votes
Thanks again Mark,
As far as I know, the fuel filter is original or 225,000 miles old. I'll replace the fuel filter and get back to you or this sight. I sure appreciate the input.
It may be a while, as the car is only needed once or twice a month when I leave my Kenworth at the shop... 45 miles from home.
Bart
Bart
Received 0 Votes
I replaced the Fuel filter. No Change. I removed the new plugs for inspection and found #3 real wet, so I replaced the boots for the plugs. No Change.
Is a coil tower the same as a coil pack? #3 was obviously not poppin'. No compression test has been done as I do not have a compression tester in my back yard (ha,ha... back yard mechanic as I am).
What should I do next?
Received 0 Votes
Based on what you have said since post #1, you really need to see if you get spark at that cylinder and if you have good enough compression to fall within at least 20% of the other 3. If you don't have an extra plug, swap with another cylinder and recheck the wetness of each plug, to see if that bad cylinder is also wet on the 'new' plug.
Received 0 Votes
If it's a 2.5 "U" the coil packs will be bolted to the ign module on the back side of the engine............If"n it's a 2.3 "Quad 4".........to access ignition components, you'd have to remove 4 bolts from the top cover. Unplug the module and invert the top cover to expose the plugs coils module and plug boots...........The large plastic piece that encompasses the coils is the coil tower..............Whatcha got?????
Received 0 Votes
You'd have to use a set of wires to test for spark getting to the plugs .......If it's a Quad 4 I'd almost bet the farm the coil tower is bad.........Acts like a bad distributer cap sending spark to the wrong place and not the plug that needs it
I believe you can rent/borrow a compression tester from AutoZone.........and I would do that just to put my mind at ease .........Q4's are 16 valve engines
so anything IS possible.........but I'd be betting on the coil tower
Received 0 Votes
Before I leave to get that compression tester, I wonder if this tower vs pack thing is one in the same? Mounted on the underside of the Quad 4 cover (plastic peice that holds the plug boots with the four bolts holding it down) is a black box. That black box has a reqular type elec conection with about 8 regular color coded wires. Is that box the coil pac mounted on the coil tower?
Received 0 Votes
I have the new coil pack/ 2 coils in my hand. Auto Zone tested the ignition modual for me and yes that is what I thought was a coil pack. We will soon see if these 2 coils fix my problem. I will let you know shortly.
Received 0 Votes
........And that is NOT the problem. No Change except for the $70 missing from my wallet. I'm still stuck... what will a compression test show me? (Auto Zone didn't have one available)
What should I do next? (BTW Ecman51, the 'new' plug was wet too)
Received 0 Votes
Hold on a sec...........Did you replace the COIL TOWER???........The big plastic piece the coils fit in???..........or the coils themselve?????......One cyl misfire is probably NOT a coil prob as when a coil fails you generally lose TWO cyls..........The TOWER can give you a ONE cyl miss.....
Received 0 Votes
[QUOTE=Barton2562;1215998(BTW Ecman51, the 'new' plug was wet too)[/QUOTE]
So now we know we have dead cylinder (as opposed to a bad plug). Either insufficient spark, or the compression is bad.
When you get a compression gauge, make sure you get the complete kit where you get the fitting at the end that fits your plug size. Mine has a screw on/off adapter for fitting a couple plug sizes.
Received 0 Votes
To ECman51;
I did a compression test as you suggested. I'm calling cyc #1 at the passenger side. #1=205 lbs/sqin, #2=195, #3 (the wet one)=185 and #4=185. I'm just guessing, but that all sounds good enough to me.
So...
To wrench47;
Yes, I did just replace the coil packs in the white tower part. Should I go get the tower too. I might as well make it all new, huh. Or is there a way to test it? I'm going out there to take it apart... hope you or somebody is around for suggestions before I get ansy and go buy one.
So...
To wrench47;
