Remove Front Disc Brake Rotor of 1990 Honda Accord
Old 06-23-07, 09:42 PM
D
1990 Honda Accord LX, 4 doors, AT, 177,000 miles. I want to change front disc brake rotor and following steps in Autozone.com (see link http://www.autozone.com/az/cds/en_us/0900823d/80/0d/1c/42/0900823d800d1c42/repairInfoPages.htm). After removing 4 bolts retaining the hub unit to the steering knuckle, I can't remove hub unit (4th picture or 1st picture under 1990-95 Accord section). I still have hub unit and steering knuckle hangging. Do I have to take it off? Is there a trick or special tool I need to seperate hub unit and steering knuckle? Any place will take this job and how much will it cost? Any comments and suggestions are appreciated! Thanks in advance!!
Old 06-23-07, 10:18 PM
C
I have done a few of these, though its been a while. I think you have to remove the knuckle completely. The other alternative involved using a hub puller but when I did that I blew the wheel bearing apart.
Old 06-23-07, 11:21 PM
D
Thanks for the replied! What is hub puller look like? Does it look like the same as balljoint puller except larger? It looks like if I take knuckle completely off, the only tool can be used is hub puller, right? Thanks!
Old 06-24-07, 09:51 AM
michaelshortt's Avatar
I do all my own brakes my self, but I sent my son to the repair shop with his Honda for the same reason. I tried several ways to get them off but they were just stuck. I think there is a special puller.
Old 06-24-07, 02:30 PM
D
Does anyone know how much it cost me for replace both front rotors and brake pads by a repair shop if I bring rotors and pads myself?
Old 06-24-07, 02:39 PM
HotxxxxxxxOKC's Avatar
Not sure if a repair shop would do since you didn't buy the parts from them, but figure about $40-70/hr and about......2-3hrs labor time.
Old 06-24-07, 05:52 PM
D
I went to autozone and try to rent hub puller tool, but they don't have. The only one they have is 2 or 3 jaws all purpose puller. It will require an about 2" - 2 1/2" circle plate to put in the center for this puller. However, I don't know where I can get this circle plate. I checked Kragen and Autozone. None of them know any of this special tool. I know it got to be some special tool for this and just don't know what it is and where I can rent/buy it. Does anyone know how repair shop seperate hub unit and steering knuckle?
Old 08-20-08, 05:14 AM
the_tow_guy's Avatar
Received 199 Upvotes on 159 Posts
I think he's probably done with the brakes by now; that thread is over a year old.
