98 jeep grand cherokee airbag window problem
Old 06-24-07, 02:58 PM
My windows and airbags are not working. The fuses for the airbags blow as soon as I replace them. The relay for the windows gets very hot. I assume its a bad ground. How do I figure it out or is that possible without going to a shop?
Any response is appreciated. Thanks
Old 06-24-07, 03:24 PM
HotxxxxxxxOKC's Avatar
Definetly sounds like a bad ground. Where to start looking is a good question. I would look at the battery terminals, specifically the ground wire. If those are ok, then I would look within the fuse box enclosure.
