Keyless Entry Code
Received 0 Votes
Keyless Entry Code
I bought a used Ford Explorer Sport Trac with a keyless entry. I did not get the the keyless entry code from the previous owner. The owners guide says the factory keyless entry code is "marked on the computer module, and is available from your authorized dealer." Rather than go to an authorized dealer can someone tell me the location of the computer module so I can get the factory code off the computer module. Thanks.
I think on your model, it's behind the backseat above the tire jack in a panel. It will have a wire harness going to it and the # will be larger and bold. You might have to look through some plastic with a flashlight, but it should be there.
Ok, I was wrong. You have to remove the defroster panel up front and look down.
Here's a direct link for the procedure.
http://www.explorerforum.com/forums/showthread.php?t=183836&highlight=keyless
