1999 ford expedition eddie bauer
where is the suspension hose located? My rear suspension will not work, I can hear the suspension motor running but no air to rear
Can you located the motor and follow the line back?
I would listen for any air leaks, if none are found, I would look at your air suspension control module which is under the dash and behind the radio.
