2002 windstar test ac high pressure switch
My mechanic told me to replace the AC high pressure switch but for $72 I want to make sure it is bad. It is a 3 pole switch on a 2002 ford windstar 3.8 v-6. Can I test it with a simple voltage/ohms tester? My mechanic said the compressor would run only if he jumped the wires on the switch plug so I would assume the switch should have continuity on at least two poles. That does not seem to be the case though.
Yes he used a manfiold gage set with the compressor running and the pressure was within normal range. What I was looking for was how to test the switch with an ohm meter. I tried a switch from an older Ford and it did not work but the older models have a different control module. I suppose the fact that it did not work makes me cautious about buying a new switch with no refund possible.
I went through a similar incident with my wifes car. I tried troubleshooting the best I could and couldn't get it figured out.
I could get the compressor to come on by jumpering the relay so I knew it wasn't that.
The dealer replaced the pressure switch with no change. Then they replaced a thermostatic switch in the air box, no change.
It turned out to be a bad control panel. I had two control panels on hand, turns out both were bad. I never knew if that was the true cause or not because when I told them I thought it was the harness because I could get the compressor to come on by moving the wiring harness going into the panel. Oh well. Good luck!
