86 S10 Blazer won't start when hot outside
Old 07-02-07, 12:21 AM
Hi,
I own an 86 Chevy S10 Blazer and for some reason when it is over 90 degrees outside it won't start. The gauges light up and when I turn the ignition key the power gauge moves like power is being used but the only thing that I here is the small click from the fuel relay.
Everything works just fine again once the sun goes down or when the temp is in the 80s or lower.
This is the 2.5L 4 cyl. 4X4.
Does anyone have any idea on what I can do to fix this?
Thanks in advance,
Glen Shaw
Old 07-02-07, 03:36 AM
check battery terminals, especially if side mount bat. Physically remove the bolts and check for corosion or bad terminals.
Trackbacks are On
Pingbacks are On
Refbacks are On
