97 sebring jxi ac high pressure switch
Hi...I was wondering if anyone knew of a step by step method of changing the ac high pressure switch on a 97 sebring jxi....any help would be great!
Easy. It's mounted behind the radiator with a harness going to it.
This switch just simply screws on/off. There is a valve within the fitting which prevents refrigerant from being discharge when the switch is removed.
The new switch typically comes with new wiring which you need to solder on and then put the heat strink material on.
I just did this job on my wifes 01 Stratus, so it's probably the same.
