Caravan horn conundrum
Awhile I posted about our 1991 Dodge Caravan's horn which wasn't working. Even after, we still weren't sure what the problem exactly was so we thought we'd try the simplest solution - replace the horn itself. A trip to the wrecker, 10 dollars, and a 2 horn set from a caravan later, the horn was working. We simply pulled the old horn, put the 2 horn set in, and plugged in both plugs. We were very happy...
A week, maybe not even a week later, we go to try the horn, and it is dead, again! The plugs are in firm, even tried switching them around but no luck.
Any idea at all why this has happened again with no warning out of the blue? What do we try now...?
Check your fuses!
If fuses are ok, the horn switch may be bad.
Easiest thing to do is run a new wire directly from the battery to a new switch, then from switch to horns.
Install a inline fuse as well.
I've seen no fuse marked "horn", but in case it's marked something else, they all have been checked and look good. Perhaps is there fuses or relays or something in a place other than the access panel by the driver's knee?
I was thinking of a simple method like you suggested too, just wiring a new setup in itself. I haven't done much electrical, but have no doubt I could do it safely/properly with some info. Just need to know what kind of wire, and the connections/inline fuse. If we keep trying to fix the other horn, it might just be a total waste with us never finding the prob.
Thanks.
Thanks.
Very easy.
Get some 18" gauge wire (auto store) and a horn switch with a inline fuse. The horns themselves should state what amperage.
Run your line from the battery (do not connect it yet) up to a inline fuse, then from the fuse to your switch. Run another wire from switch to horns.
Connect battery.
You can run this wire through an existing hole in the firewall or drill a new hole.
Check the ground wires for the horns as well.
Connect battery.
Still a few questions...
How do I connect the wires to the battery if I go this route, and how do I check the ground as well. Is ground an issue for doing the alternate circuit idea?
You can get a simple eyelit type connector to attach to the battery terminal.
The horns themselves should have the ground wires (usually black) and attach to vehicle
s body/frame, etc.
s body/frame, etc.
The solution
Problem fixed. Van was taken to get brakes done, and apparently some fuse that remained elusive to myself and others was found and replaced, and the horn works again. Thanks for the info though, I learnt a lot for experiences to come.
