Noise in the front tire area
Old 07-04-07, 12:08 AM
A
I got 2002 4 dr sebring sedan and noticed that my front tire areas are noisy. I do not feel that the tires are misaligned since ther is no vibration, shimmy or a tendency for the vehicle to "wander," or pull to one side when driven at highway speeds. Tires are not old and wear and are propely inflated but I just don't know where those tire noise are coming from. All I can think of right now is that I need to balance my tire, am I right with my conclusion? Any help?
Old 07-04-07, 04:54 AM
W
Humming noise????..............Find a straight smooth piece of road...........sway the car left to right............Does the noise increase/decrease as you change directions????...........Probable hub bearing
Old 07-06-07, 02:46 AM
A
is the noise constent or at highway speeds? if its at highway speeds its probably your wheel bearings.
Old 07-06-07, 04:31 AM
A
Thumbs up Noise from the front wheel areas
wrench47 is right..it is a humming noise that decrease as I sway my car from left to right....and the noise
is constant and not only in highways.
I would likely get a second or third opinion from a diff. mechanics atleast
I have an idea now that its my hub/wheel bearings.
Thanks guys. You are the best.
Old 07-06-07, 03:11 PM
G
Received 2 Upvotes on 2 Posts
Just as a thought, does the noise stop when you apply your brakes and return when you let off the brakes?
