I Need Some Help
How Do I Remove The Bolt On A Wheel To Remove The Axle On A Honda Civic So That I Can Change The Wheel Studs?
What year Civic?
Usually you only have to remove the rotor and tap the studs out with a hammer.
Some require pulling the hub out as well.
If you are talking about the large center nut, this should be held on my a cotter pin and probably only finger tight.
Have you gotten the rotors off yet?
After looking at the specs you will probably need a large breaker bar to get the center nut off.
You not not remove an axle to change a stud.
OK..........You've removed the rim/tire.........2 17mm bolts take off the caliper and bracket assy........At some point as the hub rotates, you SHOULD be able to sneak a new stud into position.........Then draw it in by using an inverted lug nut and washer...............SOMETIMES you may find that grinding the head of the new stud flat in one section makes for an easier install
