1998 Ford Windstar AC Troubleshooting
Received 0 Votes
Hi I have a 1998 Ford Windstar 3.0 and up until a couple days ago my Ac worked fine but now it blows hot air and the ac clutch just clicks in and out constantly Wondering if anybody had any ideas what might be causing it to do that Thanks
Received 0 Votes
I checked the pressure and it read about 100 PSI in the red zone I was wondering if that means it has some blockage and how I might clear it out, or if there might be something else wrong, Thank you
Received 0 Votes
Engine running max air on and the only place the coupler on the recharge kit fits is on the Accumulator not sure if there is any other place to put it. the other connection site is to big sorry for my ignornance about this I have not messed with air conditioning that much. Thanks for your help
Received 0 Votes
This is why you NEED a Manifol pressure SET to adjust pressure in an A/C system............Simply adding to the low side fitting without concern for the HIGH side pressure can severely damage other components in the system.......as well as
exposing the "technician" to possible physical injury
