1994 ford taurus brake light switch
Old 07-12-07, 05:22 PM
Question 1994 ford taurus brake light switch
I'm trying to fix it...how do I change out the switch without damaging anything else?
Old 07-12-07, 06:07 PM
HotxxxxxxxOKC's Avatar
What do you mean? It should just be a simple push button type switch behind the brake pedal?!
Old 07-12-07, 06:34 PM
Wink
It's not a simple push button, you have to depress a tab with a screwdriver. I meant the wire bundle it's attached to!
Old 07-13-07, 05:11 AM
W
Are you sure the brake light switch is the problem??????..........Are the turn signals working????.........haven't seen too many brake switches fail on these........Seen a TON of multi function switches...........
