92 Achieva oil pressure problem
Received 0 Votes
Hello:
I just purchased a 92 olds achieva 3.3l v6 131k; I have a few problems that I need help with;... for now its my oil pressure;
the car runs fine but the oil gage upon start up goes to 70 and if left to idle after a few minutes it will gradually got down to 40 and the "check oil" lite comes on. Also when driving it will stay at 70 but when you come to a stop it goes down to 40.
Am I doing any damage by driving this way?
What should the optimum driving level be at?
I did get a oil/filter change and that didnt solve the problem.
Any help would greatly be appreciated
thank you
thank you
It could be a faulty oil pressure switch or the oil pump.
I would not drive it to much until you get it looked at. A failing oil pump can cause engine damage.
The light comes on telling you oil pressure has dropped or to high. It may be a clogged oil pickup screen as well.
