1996 chevy monty carlo
Old 07-19-07, 07:53 AM
G
1996 chevy monty carlo has a lot of sluge build up. Any comment s on this? i am going to flush the radiator.
Old 07-19-07, 08:02 AM
HotxxxxxxxOKC's Avatar
Buy some engine sludge cleaner.
You pour this into the existing oil, run the engine, then drain and change the oil.
Old 07-19-07, 09:00 AM
the_tow_guy's Avatar
Received 199 Upvotes on 159 Posts
Heard an interesting story, and this is supposed to be true, that some dealerships are fixing sludged up engines (the ones they are having to do under warranty) by dropping the oil pan, removing the valve cover(s), masking/covering everything in sight, and then attacking it with a pressure washer or steam cleaner. Interesting; not sure if that's the way I would go or not. I would certainly try Mark's recommendation first; flushing the cooling system will have no effect on a sludged up engine (unless you are talking about the cooling system being gunked up). Ultimately you should probably drop the oil pan after using the cleaner.
Old 07-19-07, 10:33 AM
G
sorry i was in a hury. I ment to say that the radiator had some sludge build up at the radiator cap.
Old 07-19-07, 12:13 PM
Aha. Disregard the oil-related info. Flush and refill as planned. Also new cap.
Old 07-19-07, 12:47 PM
Replace motor and transmission.
Old 07-19-07, 04:44 PM
E
Received 1 Upvote on 1 Post
And upon refill you may want to consider mixing distilled water with the anti-freeze, 50/50 to reduce possibility of mineral deposits clogging radiator, choking down engine passages and heater core.
Old 07-19-07, 06:41 PM
G
ok i will do that.
But HotinOKC why would i do that is runs just fine and shifts just fine.
Old 07-19-07, 07:37 PM
I was being sarcastic!
Old 07-20-07, 07:33 AM
Gotta watch those Okie's.
Old 07-20-07, 08:04 AM
G
oh i thought you were being serious. lol
Old 07-21-07, 11:45 AM
G
This car has a anti frez leak behind the tentioner for the belt. it is a big cover on the side of the engine the were the water pump bolts to. it a little hard to explain.
This is what we are doing right now. I flushes the whole engine and put block sealer in it. we by passed the heater core (no worries there). we started at 2:00 and it wont be done till 6:00.
Old 07-21-07, 12:07 PM
G
3:07 so far the leak has stopped.
Quick question though, the ar 1800 rpms is this would be cause by a vacum leak right?
I don't have a book on this car yet.
Old 07-21-07, 06:35 PM
G
never mind throtle was stuck a little
Old 07-29-07, 01:26 PM
G
Is there any way to check the codes on this monty Carlo using a paper clip or you only can use one of those Snap on scanners?
