1998 Ford contour Parking Brake adjustment
Old 07-20-07, 09:32 AM
T
Unhappy 1998 Ford contour Parking Brake adjustment
Hello I am trying to find out how do you adjust the Parking brake on a 1998 Ford Contour SE car. The manual says that it will automatically adjust by working the parking brake several times. I changed the rear pads and ever since the Parking brake does not work. I tried the several times procedure and it does not work. Is there anywhere where this car can be adjusted. The car will not brake when pulled and even on a completed stop if I let go of the brake while applying the emergency brake the car will still roll..
Please help thanks
Old 07-20-07, 09:43 AM
T
Question re: My brake problem
I am sorry what is a Prawl?? could you send me a picture or a link where I can see how it looks like..
Thanks
Juan
HotxxxxxxxOKC's Avatar
There is a pawl on the brake handle that needs to be replaced. Remove the handle and you should see where the cable hooks into. That part needs to be replaced.
Old 07-20-07, 09:58 AM
It is a part that has notches or grooves to latch into when the handle is being pulled. Kind of hard to describe and I have no pictures to show you.
Old 07-20-07, 11:06 AM
T
Question Re brake adjustment
Also do you know what might of happen? I mean before changing the pads the Parking brake worked perfect..Once the new pads are in it did not work anymore..Also I have rear discs if that helps.
thanks
Juan
Old 10-16-07, 03:25 PM
Square Head's Avatar
Smile
You HB cable needs adjusting at the HB lever. Take the middle console out and you will see it. Also ensure cable is in good condition front to back under car.
Old 10-16-07, 05:35 PM
How did you press the rear calipers back? What tool did you use?
Old 10-16-07, 08:01 PM
Most rear calipers you do not push back in, but you have to turn back in.
Please be aware of the original post date.......
Old 10-16-07, 08:06 PM
That's where I was going with that.
Oops!. Guess I need a cup of that
Old 10-17-07, 06:32 AM
T
Well for my Ford Contour SE I did had to push the caliper back.. I rented the tool from Autozone.. It kinda like you have to twist the caliper in.. You cannot do it with a Vice Grip they do not work.. You have to use that tool.. That was the only way I could put in my new set of breaks...
Hope that helps...
