No Spark
Received 0 Votes
No Spark
I own an 85 Toyota Pickup with an 89 chevy V6 4.3L installed in it. I finished all the wiring but am getting no spark. There's power to the coil and i don't think the coil is the problem I even borrow one out of a 1990 Blazer that ran but no luck.No wires are grounded out anywhere. I can't figure it out. I would be greatful for any help thank you.
Received 0 Votes
Is this some engine swap out that you did? And what all have you rewired or tampered with? You have 12 volts going to the coil I presume - but what do you know about your distributor's current ability to create a dwell that will create the high voltage out the big coil wire?
