Grand Caravan front wheel bearings replacement
Old 07-24-07, 10:59 AM
Hi, All
I need to replace the front wheel bearings on a 1993 Grand Caravan. Does anyone know how to go about this job?
Regards, Jim
Old 07-24-07, 11:37 AM
HotxxxxxxxOKC's Avatar
Here's a link with some help:
http://www.autozone.com/az/cds/en_us/0900823d/80/10/d2/7d/0900823d8010d27d/repairInfoPages.htm
Depending on what you have, you may need a machine shop, or the special tool to remove the pressed bearing.
If the bearing is not pressed in (you can tell by looking at the link I sent you) it will be easier.
