removing door panel for a 1995 Dodge Stratus ES
Old 07-24-07, 03:42 PM
Smile removing door panel for a 1995 Dodge Stratus ES
The other day I accidently ran into my Dad's car, no really! So I need to replace the mirror on the door, I got a new mirror now I need to know how to get the door panel off so we can install the mirror. We got 2 of the screws out, the obvious ones that you could see. Now I need more info on how to do the rest of the removal. It is on a 1995 DOdge Stratus ES
thankyou
Old 07-24-07, 03:54 PM
HotxxxxxxxOKC's Avatar
Remove all screws including any in the arm handle. Wih all screws removed, I usually take a large flat head screwdriver and pop the panel off. It's held on by cheap plastic fastners that can be replaced.
Start pulling from the bottom working your way up the side of the doors.
If you have power windows/locks, just be careful when pulling the door off. You may have to reach behind he door and unplug the harness.
If it's crank windows, you may not have to do anything with the handle.
