2003 Hyundai Accent Malfunction Indicator light is on!!!
Received 0 Votes
Hello,
I have a 2003 Hyundai Accent and the Malfuction Indicator Light has just came on, does anyone know what this means and is there a way I can fix it myself??
Thank you and Godbless
SSG David Wilcox
U.S. Army
SSG David Wilcox
U.S. Army
Bring it by a Autozone to get the trouble codes read for free. They will tell you what the code means, and/or come back here and let us know.
Hooah!
Good luck from fellow SSgt.
Hooah!
If everything seems to be running okay, how long has it been since the oil was changed? Some newer cars will pop up the check engine light when you are due for an oil change. The manual should tell you how to reset it, or the oil change shops "should" know to reset it.
Received 0 Votes
Changed the oil and everything works great!!! Thanks for the help!!!
