Headlight Replacement
Old 07-30-07, 12:53 PM
thiggy's Avatar
I have a 1997 Dodge Intrepid with a burned out headlamp on the driver's side. I have been totally unable to determine how to remove the assembly to change the bulb. I checked the Motor Manual in my library, but it doesn't address this. Does anyone know specifically how this is done? Thanks
Old 07-30-07, 01:40 PM
New guy's Avatar
Open the hood, there are 2 small bolts (7mm or 9/32" socket) on the top, remove them and then slide the whole headlamp assy out. The bolt head is small (7mm) but they are about approx 6" long.
