90 shadow won't shut off
Old 08-03-07, 02:59 PM
L
my son has a 90 shadow 2.2 auto. replaced fuel pump and ignition switch. Only problem now is car will not shut off. Turn key off motor continues to run. It's not diesling. Only shuts off when coil wire is pulled. Any information would be appreciated.
thanks
Old 08-03-07, 03:36 PM
E
Received 1 Upvote on 1 Post
Did this problem surface right after the igniton switch was put in? I mean, literally right away afterwards? And who installed it?
Old 08-06-07, 04:00 PM
L
90 shadow
No, problem was there before. I think I've found the issue, but don't know what to do about it. There is an (i think) accuator rod. I believe it is worked by the key switch. Well, there's nothing there. It's gone. I have one in a 94 duster, but don't know how to get it out. Any help with a steering column disassemble would be appreciated.
Thanks for the info.
