Service engine light on 96 Buick Century
Received 0 Votes
I have a 96 Buick Century with only 83,000 miles on it. Yesterday the "Service engine soon" light came on and has stayed on. I took it to Autozone where you can get a free code reading for cars 96 and newer. The associated told me the code identified a vacuum leak and the ev canister, but told me the ev canisters do not go bad. I spent some time this evening looking for the obvious-a loose hose connection or an obvious hole in a hose. Did not find anything. Both hoses to the ev canister are secure and look ok. Three questions I am wondering if someone can help with:
Could it be the ev canister anyway?
Any common places or hoses to look for a hole or crack?
What is the easiest way for a back yard mechanic to check for a vacuum leak?
Thanks!!
Thanks!!
Received 0 Votes
It's cheaper and easier to replace all vacuum lines because once one goes others are not far behind but to check them get a spray bottle and spray the lines when you see the bubbles thats the leak. good luck
