chevy celebrity 87 2.8l low Coolant light staying on
Old 08-12-07, 03:03 PM
I've got a 87 Chevy Celebrity 2.8L model. Every time I crank the car the low coolant light comes on and stays on. The radiator is full with a 50/50 mix. It's got a new thermostat and a new water pump and everything seems to be working fine. I think it may be a faulty sensor somewhere. Any help with this would be much appreciated.
Old 08-12-07, 03:09 PM
HotxxxxxxxOKC's Avatar
It does sound like the sensor. This sensor is usually located at the bottom of the coolant reservour. If this light is annoying you, you can unplug the connector plug underneith and the light will go out until you get it replaced.
Old 08-12-07, 03:19 PM
Can that sensor cause any problemes with coolant flow? I just had to do a head gasket replacement because the water pump and half a dozen hoses went out. I don't want it to happen again. So could that sensor cause any trouble?
Old 08-12-07, 03:36 PM
No. The sensor just lets you know when the reservoir is low on coolant. It is common for these to fail, especially if the reservoir has ever ran dry. It's a fairly easy fix.
Trackbacks are On
Pingbacks are On
Refbacks are On
