Will This Short A Battery?
Isn't it wrong to clean the blue powder off a battery by pouring a baking soda solution ALL OVER THE TOP OF THE BATTERY AND TERMINALS? It seems that this would run a short through that conductive liquid and drain a portion of the power.
Baking soda, a dab of water, and when it quits sizzling scrub the terminals with an old toothbrush and then wash the mess off with plenty of water.
I usually then dry the top of the battery and posts with paper towels.
P.S. Don't use the toothbrush anymore for your teeth. LOL
I use my sister's toothbrush
But the answer to the question is, technically it could
But it would take quite a bit of standing water
The process described is not likely to ruin the battery
And it's "healthier" for the battery to be clean
Links with detail
Here is some more detail on the subject (if you have an hour).
http://www.repairfaq.org/ELE/F_Car_Battery.html
http://theoildrop.server101.com/forums/showflat.php?Cat=0&Number=920788&page=0&fpart=1&vc=1
