oldsmobile intriguie
Received 0 Votes
how do you replace the wheel studs on a 99 oldsmobile intriguie for the front and rear tire's cause some of mine are strip.
Most cars you can remove the caliper and rotor and take a ball pean hammer and knock them out the back.
To install, you insert your new ones, then take a lug nut and tighten it to draw the stud all the way back in.
