not getting spark
Received 0 Votes
not getting spark
96 elantra, dosn't seem to be getting any spark, was driving and it just stoped, turns over but won't start, dosn't have a round distribitor so don't know how to check if it's timming belt or not or if it's something simple, i put a screw driver in the end of the plug wire and held it close to the block and tried to start it, but no spark. just at a lost at what to check or where to check. as you can see i'm not that bright on auto repairs. any ideas????
Timing belt would be a possibility; recommended replacement on you car is 60,000 miles and it IS an interference engine, so pray it's not the timing belt. Try removing the oil filler cap from the valve cover and look in to see if you can see valves, rocker arms, or camshaft. Have someone crank it over while you look in; watch to see if things are rotating or going up and down (good, belt not broken) or just sitting there (very bad, probably broken).
Received 0 Votes
not getting spark
Hat, please stick with one post, so that everything can be viewed in one spot. There should be a fuel pump fuse under the hood, probably in the power distribution box.
Here is a way to check the fuel pump. On your command, have someone turn the key on to the run - but not start - position. Get as close to the gas tank as you can before giving the command. When the key is turned on, you should hear a whirr or buzz sound for a few seconds. If you hear it, the fuel pump is getting power.
