transfer cases removable?
Received 0 Votes
I have an automatic transmission on a 4wd 85 S10 and I was curious, are the transfer cases removable so I could use the tranny in a 2wd?
My very uneducated guess is that yes, the transfer case can be removed and the transmissio used as a 2WD, but another piece will bolt to the back of the transmission where the transfer case used to be (A cone shaped piece with an output spline shaft for the drive shaft).
