Cylinder compression for Ford Explorer 4.0L 1991 ?
Old 08-29-07, 06:06 PM
Question Cylinder compression for Ford Explorer 4.0L 1991 ?
Hello:
I have a old 1991 Ford Explorer with motor 6V 4.0L
The motor have 2 cylinder with no combustion ..
I install new spark plugs and run the motor for 2 hour ,,
then I check the spark plugs and that 2 cyilinder shows the spark plugs very clean..
The others ones are dirty ..
I think I have problems with the fuel injector system ..
Any suggestion ???
I want to know the tipical cylinder compression (lbs.) for a used Motor of Explorer 1991 . ( the motor was rebuilded 6 years ago ) (4.0L)
Thanks in advance
Old 08-29-07, 06:28 PM
HotxxxxxxxOKC's Avatar
I believe it is 175psi and all cylinders should be with 10% of each other.
Trackbacks are On
Pingbacks are On
Refbacks are On
