1990 Eldorado Inflatible Restraint Light
Old 09-02-07, 05:56 PM
Question 1990 Eldorado Inflatible Restraint Light
My 1990 Eldorado Inflatable Restraint light is on. A shop told me it was due to a bad clock spring. The SIR code is R21. Is there some way for me to double check this diagnosis? Just what is a clock spring? It's supposedly in the steering column. I can't find the part on various Cadillac parts boards.
Old 09-02-07, 07:41 PM
HotxxxxxxxOKC's Avatar
It ensures a positive connection between the steering column wiring harness and whatever controls are on the steering wheel, and especially the airbag.
I would suggest having a trained mechanic change this if at all possible.
Part is fairly expensive as well, around $200. You might have better luck pulling one off a salvage yard model.
All Cadillacs 90-91 have the same one.
http://www.newcadillacparts.com/cadillacparts.htm
Old 10-20-07, 07:16 AM
Red face 1990 Eldorado Inflatable Restraint Light
Thanks for the reply. I managed to get the light to turn off by doing the following:
1) I moved the car to my driveway. It has a slope.
2) I positioned the car with the nose pointing towards the
bottom of the slope to ensure it was lower than the rear.
3) I started the car.
The Inflatable Restraint light blinked a few times and then went out.
The procedure works anytime the light goes on, which has been only twice since then.
The light seems to go on when I start the car with the rear much lower than the front. That happens when I'm starting it on a hill or when I have a load in the trunk.
The rear shocks are shot so the auto leveling doesn't do much.
Any idea? Can it just be something loose or related to the rear shocks?
