Honda CR-V dash clock
Old 09-04-07, 06:13 AM
daswede's Avatar
Anybody have any idea on removing the clock? Clock isn't working,or the bulb is burnt out.
Thanks
Old 09-11-07, 07:48 AM
C
I changed the clock bulb on our 2000 Accord a few years ago. We could see the clock display in daylight but not at night, so the clock was working, but the bulb was burned out. If you can't see the display in daylight, then the Liquid Crystal Display is probably kaput. I don't know if the CR-V clock is the same or not, but it's probably similar. In the Accord the clock snapped into place from the front, but it wasn't easy to remove without damaging the trim ring.
Old 09-11-07, 07:58 AM
daswede's Avatar
I suspect you are correct in that the LCD display is gone.
Its also like your accord display in dash mounting. I think the fix is to just get one of those small stick-on clocks for the dash.
Thanks for your reply.
