92 nissan missfiring1.6 engine
Old 09-11-07, 04:51 PM
Question 92 nissan missfiring1.6 engine
Ive replaced the plugs&wires&adde fuel injector cleaner still idles very rough missfires. Is there a component thats called an idle speed sensor&where is it located &could that cause the problem or what else may it be?Thank u!
Old 09-11-07, 05:13 PM
E
Received 1 Upvote on 1 Post
Did you find anything wrong with the last set of plugs when you changed them? And do you still have them where you can carefully look at them? Often people overlook to see if a plug has been steam-cleaned (head gasket failure sign), or if one plug has a fine hairline crack in the cone-shaped insulator near the tip of the plug by the electrode. (A steam-cleaned plug is really prone to the cracked insulator) - or if you have a lot of carbon inside as that can cause engines to fire at will/misfire.
There are a lot of things that can cause your miss, but I'm first curious what you have to say about your old plugs you changed.
Old 09-12-07, 12:55 PM
Question re92 nissan missfires
Plugs show normal wear they are all a light brown color.
Old 09-12-07, 03:06 PM
HotxxxxxxxOKC's Avatar
Did you change the distributor cap and rotor?
Old 09-12-07, 05:43 PM
E
And it runs real good otherwise?
Old 09-13-07, 05:37 AM
Question re92 nissan missfiring
No I didnt change cap&rotor, but too k them both off&they looked ok, took it a step further&sprayed water into Dist.cap while eng. was idling& made no difference eng ran the same&yes ,other than the eng. missing it runs ok otherwise.
Old 09-13-07, 03:05 PM
E
You only answered my question partially. I wanted to know if it just misfires while idling - only.
Why did you spray water? WD-40, yes. But water?
Old 09-13-07, 03:23 PM
Water === corrosion. You will probably have to replace the cap and rotor for sure now.
Old 09-13-07, 03:27 PM
hopkinsr2's Avatar
He probably sprayed water onto his plug wires with the engine running because if there was a leak in the cap or rotor, it wouldn't catch fire like WD-40. Jimfh, did you spray any water around the area where the intake manifold meets the cyl head to see if it makes a differance, or funny sounds. And as mentioned earlier, does it only miss @ idle, or even @ higher revs?? Roger
Old 09-13-07, 04:11 PM
G
Received 28 Upvotes on 27 Posts
Replace the cap and rotor since you have already changed plugs and wires, a cap can look like new and still fail. Have a good one. Geo
Old 09-13-07, 06:01 PM
92nissan missfires
Yes It Missfires All The Time.
Old 09-13-07, 06:40 PM
G
How many miles are on the car? Get a inline spark tester and attach to each plug until you fine the one that is failing then run a compression test to see if the cylinder has proper compression. If you have compression, spark and fuel it should make smoke and noise(a lawn mower guy expression). Have a good one. Geo
