1999 Chevy S10 Blazer air/smog pump hose burned
Old 09-12-07, 01:58 PM
G
My Blazer has a pump under my radiator and can't tell if it's working. Been told it's an air/smog pump. The tee fitting melted and so did the 90 degree rubber hose below the alternator which goes into a check value. How can I check the pump?
Old 09-15-07, 01:17 PM
B
ok check valves on the air tubes are bad blowing exhaust back into ur hoses also up north here was very common for water in the air pump to freeze
if u take the hoses off at the exhaust manifold airtubes and start the truck u will hear it and feel it leaking exhausht past the check valves
Old 09-16-07, 01:31 PM
Oh yeah, we see alot of these come in with water in them. Do you recall if the service bulletin has been performed on your truck for the secondary air injection system?
