1993 sundance
1993 sundance
Does anyone know if there is a relay or fuse for fuel pump for a 1993 Plymouth Sundance 2.2?We have changed fuel pump but still not getting any power to the pump.But when bypassed and hooked up direct to battery pump is working.Thanks.
relay location: Under hood, driver side, front side of strut tower, mounted in relay block on inner fenderwell
I would suspect there is also a fuse for the thing as well. I don;t know where those are found but many of todays cars have multiple fuse blocks with things such as this in a block in the engine compartment as well.
If you have the owners manual, it may specify where the fuse can be found.
if i remeber right there should be a relay box on the left side under the hood
should have fuel pump fuse fuel pump relay and an autoshutdown relay both the relays need to work for pump to work
