front end problems
New Member
Received 0 Votes
front end problems
I have a 2004 ford ranger (i'm the original owner) and just started having trouble with the front end....at low speeds it creak's...like two pieces of metal rubbing together...any idea's on what to look for.....Thanks
I have notice some Fords, not just trucks, wearing out ball joints. I would start there. Look for busted dust boots on the joints them selves. You may want to check the outer tie rods also.
Received 0 Votes
Ford has had problems for years with their suspension components............04 I'b be looking at the upper ball joints if it has stamped steel upper A arms............You'll probably se torn boots............and NO grease fittings so once the lube gets OUT and the dirt/water gets IN you're pretty much done for
