2001 dodge intrepid belt
Received 0 Votes
Is there a simple way to change the serpitene belt on the intrepid.Ive loosened the nut on the tensioner and I cant get a wrench to the bolt on the adjuster.Is there a special way to get to the adjuster?
Not sure how similar the 1st generation Intrepid's are to the 2nd gen, but when I did the belts on a 95 I believe I had to use a box end wrench which was long enough and had enough clearance to slip onto the head. Do you have a Hayne's or Chilton's manual? Usually they have a few tips and tricks. Also check www.dodgeintrepid.net
Received 0 Votes
I did a 2.7 Litre about 2 months ago in a 1999 Intrepid.
Seems I remember ?????????????-------
Just a wench after the tensioner was loosened.
Was simple after I did it.
Are you working on a 2.7 V-6 ??
