2000 F150
Received 0 Votes
Are the manifolds cracked or are they just leaking at the mating surface? When you put the stock manifolds on did you install new gaskets and clean the surfaces?
With a clean surface, new gaskets and proper torquing of the manifold bolts, they shouldn't leak.
As for the clutch problems, it sounds like a hydraulic clutch with low fluid. Check the level and fill as necessary. If you still have the problem, you likely have a bad master or slave cylinder that should be replaced or reconditioned.
Since the manifold leaking and the clutch problem are running together, make sure your leak from the manifold didn't melt a clutch line or boil fluid from the clutch system.
Hope this helps,
Bob
Hope this helps,
Bob
Received 0 Votes
Anyway...I am going to go look at it right now to see if the manifolds are cracked or if they are leaking at the flanges, or connecting point and then check the clutch fluid as you recomended....Thank you for your help, Ill let you know what I find out.....
Thanks Again!
Received 0 Votes
Thank you Bob for your help!
