Gas tank removal
Received 0 Votes
Gas tank removal
I have 2 gas tanks in my 1991 Ford pick-up. The fuel pump has been bad for a year now in my front tank. Now it has a hole in it. I removed the tank. Can I cap off the fuel lines and use just my rear tank?
Yes. Just make sure you use a correct fitting cap that screws on tightly to the hose.
Also make sure you tape up the electrical connector to the old pump and tuck it away where it won't get damaged.
