1993 chev astro,power window problems.
When I try to roll up the window it stops .Then I have to wait for awhile then try again.It take's 4or5 try's to get the window up.Any help on what it could be?
It could be in the slide tracks for the windows or the rollers/track that lift it. It certainly sounds like something sticking. You can try lubing the the window tracks with silicon lubricant. With the windows down, spray the tracks and check them for damage that may hang up on the glass.
If that isn't the problem, you'll have to pull the door panel to access the lifting mechanism. Once you do you can either lube those parts or see what parts you have to replace.
Hope this helps,
Bob
Hope this helps,
Bob
