2003 chevy venture stalling
Received 0 Votes
I have 2003 chevy venture and it stalled out when i was slowing down. I started it and continued to drive. the battery seems fulley charged. I have noticed 2 or 3 times in the last 6 months that it stuttered in the driveway as i put it in reverse to back out of the driveway after starting. but it did no stall and i proceed to drive without any problems. what could it be?
Received 0 Votes
Hey I was just thinking that the Idle Air Control Motor or IAC may be shorted out internally or sticking due to carbon build up. I would take it off check the carbon build up on it.
Received 0 Votes
Where do you buy gas at? You may want to try somewhere else, as we have had a number of vehicles come in with symptoms such as yours, all cured by changing gas stations, and/or flushing the fuel injectors.
Gasoline Brands That Currently Meet TOP TIER Detergent Gasoline Standards
As of November 15, 2006, all grades of the following gasoline brands meet the TOP TIER Detergent Gasoline Standards:
• Chevron
• QuikTrip
• Conoco
• Phillips 66
• 76
• Shell
• Entec Stations located in the greater Montgomery, Alabama area.
• MFA Oil Company located throughout Missouri.
• Kwik Trip, Inc. in Minnesota and Wisconsin andKwik Star convenience stores in Iowa.
• The Somerset Refinery, Inc. at Somerset Oil stations in Kentucky.
• Aloha Petroleum
• Tri-Par Oil Company
• Texaco
Top Tier fuel is what GM recommends for their vehicles. The companies listed above will have this fuel. If the problem diminishes while using the Top Tier fuel, continue using it. If you are already using it, a number of things could be causing this problem. You may need to have the fuel injectors professionally flushed, and then continue using a Top Tier fuel.
• Chevron
• QuikTrip
• Conoco
• Phillips 66
• 76
• Shell
• Aloha Petroleum
• Texaco
