93 toyota canry tube
Received 0 Votes
Hello All
I have a 93 Toyota Camry xle, v6. The question is that there is a tube that comes out underneath the car, just behind the front axle. Looks to me like water is dripping out of it. But I can't figure out what it is for.
Thanks
Thanks
Received 0 Votes
Also located a hole in the bottom of the trunk which I assumed should have accommodated the tube. Pushed the tube through the hole, bound it with duct tape to keep it there and have not experienced a problem since.
Am still puzzled as to the source of the water.
It's either a regular (rain) drain or a/c condensation drain
Might be the sunroof channel drain; not sure how it would be routed in your particular make/model, but not out of the realm of possibilty it could be routed through the trunk area you describe. Try running some water over the sunroof (closed tight!) and see if water doesn't trickle out the tube.
Received 0 Votes
Threw a bucket of water over the sun roof, five minutes later a pool of water formed in the driveway under the trunk.
It was seeping through the tube I redirected through the bottom of the car.
Incidentally, the vehicle is a 1988 Toyota Camry LE 6 cyl.
Original paint, 243,000 km, still burns no oil between oil changes, no rust and in close to showroom condition. Wouldn't trade it for a 2008 model.
