citroen c15 van, deisel. P reg.
Received 0 Votes
have a citroen c15 van P. reg.
reversing lights not working. Have changed bulbs.
all other lights are working.
There is no live feed from the gearbox to the fuse.
Can you advise.
Can you advise.
Last edited by twelvepole; 10-07-07 at 09:17 AM. Reason: Moved post from outdated thread
Received 0 Votes
put new bulbs in' still not working.
all other lights are okay.
Fuse for reversing lights is okay.
There seems to be no live feed from the gear box to the fuse.
Where is the reversing switch located by the gear box.
Can you help. Yvonne.
Last edited by twelvepole; 10-07-07 at 09:18 AM. Reason: Quote removed. Not necessary to quote an entire post in order to reply.
The original post in this thread is 3years old and I don't think that member is still around.
I'm not real optimistic that you'll get an answer here on your Citroen; it's the first question I can remember EVER being posted concerning one. What I would do in your case is figure out where you would get a replacement switch from (where DO you buy Citroen parts in the US???) and get a look at one. Seeing what the part looks like may give you a clue as to what to look for. It's also possible there is a switch in the console, near the shifter, for a floor shift, or in the steering column area for a column shift.
Good luck.
Good luck.
