brake bleeding
Received 0 Votes
brake bleeding
I am going to try to bleed the brakes an my 1991 ford fi50. i am having trouble finding the bleeder valves. are they on the back side of the drum and do i have to remove the wheel and tires.
thanks in advance
thanks in advance
Here's some help:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Youi don't HAVE to remove wheels to do the job, but it gives you more working room so you don't have to crawl underneath. Be sure you properly support the truck on jackstands if you work with wheels removed.
Brake Bleeding
I'm sorry to sound this way but if you are having a problem finding the bleeders on the truck maybe you should let a service station do the job. There is a proper procedure for the job and what is the reason you are bleeding them in the first place?
Received 0 Votes
Brake bleeding/line replacement
I am not a Ford guy but I did some brake work in my Chevy when it was about the same age as your truck. A couple of things to consider: before you start trying to take anything apart, give the threads some good doses of a penetrating oil. I swear by PB Blaster. For me, if anything works, it does. As best you can, wire brush the connection to loosen first. Then soak it several times over several days. Old brake lines are a b(^*!@ to get apart.
Think about replacing other joining lines while you are at it. You might have to anyway if what ever you need to change wont come apart from its mating line. I had that problem.
Also I would but a new bleeder valve. Its a couple of bucks and not worth screwing with the old rusted one.
The actual bleeding isnt bad. With a 30 yr old Triumph, I have coaxed/trained my wife into an able assistant.
Good luck.
Good luck.
Received 0 Votes
I had same issue with you before..but my brother fix it using the my car manual..you might want to check it in the manual...
__________________[I]
NO ADVERTISING ALLOWED. YOU ARE GOING TO BE
