94 Jeep Grand Cherokee ignition switch
Received 0 Votes
I think my key switch has gone bad. It feels loose and the Jeep will not start. How do I remove that barrel to replace the switch? If thats what it needs
Received 0 Votes
Received 0 Votes
might check out autozones website for more info would suspect it just requires a pin to be depressed to remove the cylinder after removing steering column covers.
when you get the cylinder out take a look at it and see if its broken usually pretty obvious, as your problem could be in the ignition switch.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
